NodeAlias.SndCkptFail
Description
Nodealias module was unable to checkpoint a nodealias entry from the primary to backup node. This will result in fewer number of nodealias entries learned on the backup node.
Remedy
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help. This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: Output of 'show nodealias', 'show nodealias ports all'
Severity
Error
Message Text
Send checkpoint message failed for aliasId %aliasId%.
Message Parameters
Name Type
aliasId uInt32
